hc162 aileron progress
ssearle
Post by ssearle »
This is my aileron progress.
Home made Dies to use with readily available press.
Aileron Skin dies.JPG (65.59 KiB) Viewed 4636 times
Aileron skins and parts lowe r wing.jpg (87.31 KiB) Viewed 4636 times
Aileron skins and parts.jpg (70.9 KiB) Viewed 4636 times
Orig Waco aileron.JPG (79.34 KiB) Viewed 4636 times
Orig Waco aileron view 2.jpg (64.15 KiB) Viewed 4636 times
ssearle
Re: hc162 aileron progress
Post by ssearle »
More pictures
Aileron lower left.jpg (87.59 KiB) Viewed 4635 times
Aileron lower right.jpg (90.9 KiB) Viewed 4635 times
An other way to form aileron spars is to use form blocks like making ribs.
Aileron spar form blocks.jpg (74.16 KiB) Viewed 4635 times
painless
Post by painless »
Very nice! How about more pics of your skin dies? I'm planning to do the same when the time comes.
Jeff Orear
Hatz Classic #138
Peshtigo,WI
ssearle
Post by ssearle »
Hello Jeff
As it so happens I screwed up. When building the last aileron I found that I had two lower skins left(12in wide). Some where I had used an upper skin (12.5in wide). I'll be setting everything up again to press another skin so there will more pics.
painless
Post by painless »
Well, it's good to know I'm not the only one that screws up! Long story short, I learned how to do splices in tubing this weekend.......
Looking forward to the pictures.
Jeff Orear
Hatz Classic #138
Peshtigo,WI
ssearle
Post by ssearle »
Hi Jeff
Thanks for your interest. I'm a do it your self type guy. If I think I can do it I'll give it a try. I research everything I can find on an topic, put in a pot, stir it up and add my own ideas and come out with my plan. I've built a big heap of scrap metal in the process, but this is my thing, I have more time than money. Incidentally a lot of this scrap gets reused.
Regards Steve
Great photos!
I've also made a mess of some things during the process.... part of the fun I reckon!
Looks like you are doing very nice work! Thanks for posting, keep em' coming please! Very interesting and satisfying to see how folks are doing things out there.
Rick
