Landing Gear Parts
Jackal
Landing Gear Parts
Post by Jackal »
Hey guys,
Where to get the axles and springs for the landing gear. It shows the axles are Cessna 170 or 182 axles, but I think if I call Cessna and say I need new axles for my Skyhawk/Skylane I will pay too much!!
What about the big springs in the gear??
Re: Landing Gear Parts
The axles are not Cessna axles. Cessna axles are designed to bolt on the landing gear. The axles on the Classic plans are welded on and are available from ACS & others.
http://www.aircraftspruce.com/catalog/l ... _nuts5.php
The springs are also available from ACS. I've also seen them in McMaster Carr.
http://www.aircraftspruce.com/catalog/l ... absorb.php
Jackal
Post by Jackal »
Thanks Doug. Actually I'm building a CB-1, but posted the Classic forum because it seems more active. My plans show bolted on axles - I assumed that was common between the two plans, but probably I could do it the Classic way and weld them on.
I'll look the springs up there, as you suggested.
Thanks again.
A/C Spruce has several bolt on choices listed.
http://www.aircraftspruce.com/search/se ... &x=21&y=12
Jackal
Post by Jackal »
That was easy. Thanks!!
Sorry about that. You're right that the CB-1 axles bolt on. As Jeff pointed out, ACS has a number of options.
