HC #86 Update
- splischke
HC #86 Update
I just finished cutting the finishing the floor boards. It was a bit tedious work but I enjoyed it. The EV-400 Epoxy varnish really shines!
- Floor board ready for sanding and finishing.
- normal_SAM_0158.JPG (73.49 KiB) Viewed 4656 times
- Polyfiber EV-400 really shines.
- normal_SAM_0164.JPG (63.85 KiB) Viewed 4656 times
Re: HC #86 Update
I enjoy the photos on your website; they help a lot. Looking good there Scott.
Re: HC #86 Update
Here is a suggestion that worth adding on the Classic with the stepped floor boards.
- Heel Plate01 03-06-05.jpg (388.1 KiB) Viewed 4632 times
- splischke
Re: HC #86 Update
Great idea and easy to implement. Thanks!
Re: HC #86 Update
Can anyone explain the reason that the floor is higher in the rear of the Classic. To me the step seems to create a problem with the ruder pedals. I like the ramp suggestion but why not just make both floors the same elevation. Is there any interference that I am not seeing?
Re: HC #86 Update
The raised floor provides clearance for the aileron push tubes which run under the floor.
