PEM nuts
jdgleitz
PEM nuts
Post by jdgleitz »
Has anyone found a source for the compression tube PEM nuts, or another suitable 528 weld nut?
JD Gleitz
HC-129
Re: PEM nuts
McMaster Carr has them
http://www.mcmaster.com/#pem-style-nuts/=h3f6y8
I ended up making my own on a lathe. The ones in the center of this pic:
http://www.damowry.com/hatz/displayimag ... fullsize=1
And tack welded in place in this pic:
jdgleitz
Re: PEM nuts
Post by jdgleitz »
Thanks Doug. Not sure why I didn't find them in McMaster Carr.
Those you made look very nice. It doesn't look like too much trouble to do at the same time as the tube end fittings.
JD Gleitz
HC-129
Re: PEM nuts
You're right, they really aren't any different than the larger fittings and machining them is all the same process. The lathe I used had a collet setup so making these was really easy.
