Here is what the Stewart System fabric manual states;
Fabric to Metal - EkoBond Cement (E610) is used in a different manner than most aircraft cements. Apply EkoBond Cement (E610) to the surface where the fabric will be attached. Let the cement tack up (tacky to the touch, approximately 5 minutes, depending on temperature and humidity). Apply the fabric to the cemented area. Using your hand, remove excess wrinkles, then with firm pressure rub fabric onto cemented areas. This will gently hold fabric in place. When fabric placement is acceptable, use a Close Quarter Iron set at 275 to 300°F and make a single pass over the cemented area, using firm pressure. This will heat the glue and hold fabric in place. You will see a glue bond of about 1/16” to 1/8” wide where the iron heat bonded the glue. Brush additional glue down through the fabric to the cemented area and wipe away excess with a blue Scott paper shop towel or equivalent while at the same time smoothing the fabric down. The cemented area should show an even color indicating a complete bond to the substrate. Drying time will depend on temperature and humidity. When installing inspection rings or reinforcing patches, use EkoBond Cement like contact cement: apply to both surfaces, allow to become tacky, and then press the surfaces together.
They also just came out with:
EkoBond - Glue and Sealer- "LINEN" ...The Lined colored EkoBond was developed for use in the cabin area of aircraft where there is no interior and you see the back side of the fabric. For antique aircraft and biplanes it gives the classic look of a cotton or linen covered aircraft when viewed from the inside of the aircraft. The fabric and tapes are applied normally with the linen colored EkoBond. Then you dilute the linen colored EkoBond up to 10% with distilled water and brush or roll a coat into the weave of the fabric from the out side. Then a x-coat of the White E620W EkoFill is sprayed on to lock in the linen color. The white EkoFill is followed up by 3 x-coats of Grey E620 EkoFill before the top coat paint is applied.
Sounds like you are really moving along Jeff. Please do post some pictures!
I too plan on using this painting system.
Blue skies,
Keri-Ann
