TIG or gas?
Re: TIG or gas?
I am welding 4130 and am using ER70S6 filler rod. The ER70S6 is currently recommended by Kent White of Tinmantech and is easier to obtain than the R-45 since it is used for both gas and electric. I have read that it sparks more than the R-45 but I have not noticed any problems.
Read a little here from tinmantech.com: https://www.tinmantech.com/html/welding ... msteel.php
I have his Meco Midget torch and a full set of tips and I have been using it to weld the 4130 and also aluminum. For the fuselage if you only had one torch I would go with that one. It is a little pricey but I am glad I got it along with the light weight hose.
Keep warm.
Ed
Re: TIG or gas?
Thanks, I'll check that out.
Re: TIG or gas?
Check your local welding supply house. I can get filler rod (R-45) locally.
Re: TIG or gas?
Thanks Doug...I found a local supplier selling RG-45:
Product Name: INWELD TIG ROD TIG RG-45 1/16 x 36 x 3# TUBE (oxy fuel welding)
Product ID: INWMTP3RG45062
Manufacturer: Inweld Filler Metals
GTS Price $13.30
Will I need a thicker than 1/16 rod at some point?
What do you think about this place and prices? Would you buy filler here? It says house brand, but it appears to be AWS certified. https://weldingsupply.com
Re: TIG or gas?
PoconoJohn wrote:
Will I need a thicker than 1/16 rod at some point? St
What do you think about this place and prices? Would you buy here? https://weldingsupply.com/cgi-bin/einstein.pl
1/16" is all I've needed. I don;t imagine you'll need anything thicker. Those prices look ok. As long as you get what you pay for then you should be good. All places like ACS , etc are doing is sourcing welding rod from existing suppliers.
Re: TIG or gas?
That was a fast response....thanks again.
Re: TIG or gas?
Any good local welding supply shop should be able to provide the proper rod for the type of metal you are welding. Just tell them what welding equipment you have and that it's for 4130 steel.
John Hanson HC012.
Re: TIG or gas?
I'll buy the ER70S6 from tinman (along with full face shield)...how many pounds do you think I should get? I'll be practicing a lot also.
In other news, I decided to just get everything Smith...I think :roll: (from ACS):
AW1 handle
AW201/3/5 tips
RA921 twin hose
the single stage regulators
along with tip cleaners, flint lighter, welding apron and two bags of practice tubing
Did I miss anything?
